Open source tig AC/DC project
Raban
AMMINISTRATORE
Messaggio da Raban »
Project Description:
The project consists in building an inverter-based combination
TIG and Stick welder based on a PIC 18F4431 microprocessor. The
welder is open source & uses readily available discrete components.
In addition, the build is modular: the welder can be built in whole
or in part, as required.
For example:
-Build just the inverter for pulsed DC TIG/Stick welding (scratch-start)
-Build just the second AC module for Tig welding aluminum (square wave)
-Build the third, High Frequency start module, to add HF starting.
Technical details:
-230V single phase
-75V Open Current Voltage
-225A Max Current
-255HZ max AC frequency
-0 to 100% wave balance
-20-80% phase current balance
-accepts a foot controller
-Pulsed DC: adjustable base & max current, frequency & duty cycle
-selectable start polarity
-selectable start current
-selectable HF start time
-ability to store up to 10 programs
80kHz PWM Transformer frequency
20kHz Closed loop Frequency
80kHz ADC current sampling
Complete details available at meccanicaedintorni.morpel.it
- internet + cabernet
- V8 Power
ALMOR
AMMINISTRATORE
Re: Open source tig AC/DC project
Messaggio da ALMOR »
very good my friend!
Garkoll
Messaggio da Garkoll »
Ma detta in italiano!!! :grin: :grin: visto il grande lavoro che state facendo ma a che punto siete arrivati??? :grin: :grin:
Raban
AMMINISTRATORE
Abbiamo fatto un test in dc a 90 A ed e' andato bene , a 120 A e' saltata una scheda questo perche'
la nostra saldatrice esce ad una tensione troppo alta ( 75 V) , causa rettificatore full bridge .
Il test fatto a 90 A 75 V e' quindi equivalente a un test 180 A 37 V , siamo in attesa che arrivino
i componenti elettronici per riparare la scheda saltata e ripetere i test
- V8 Power
Garkoll
Grande Raban!! :inchino: :inchino: :grin:
allora attendiamo il botto serio!!! :rotfl: :alcooli2:
Che roba e ?
Raban
AMMINISTRATORE
una spiegazione sommaria del progetto tig , fatta in inglese per gli amici anglofoni
- V8 Power
Si, quello lo ho capito ma mi riferivo a quello sproloquio che c'era ieri e che ora evidentemente è stato rimosso.
erano messaggi di spamm li ho rimossi io , almeno 20 " lì mortee".
Infatti... l'argomento non era esattamente la meccanica... o la grammatica :risatina:
nestorio
Messaggio da nestorio »
come cazzarola tolgo il messaggio?
Rimossi...
Torna a “Tig open source - discussioni generali”
